Does remote disc/CD sharing work with audio cds?
I
iMore Question
Can I insert an audio cd (music album) into the Mac with an optical drive then use remote disc to access the cd from the Mac without the optical drive then transfer the cd to iTunes? Does it work with music albums too or only software and DVD's?
59,642
618
“DVD or CD sharing isn't designed for some kinds of optical media. Connect a compatible optical drive directly to your Mac if you need to use one of these discs:
* Audio CDs
* Blu-ray or DVD movies
* Copy protected discs (such as some game discs)
* Recordable CDs or DVDs that you want to burn or erase
* Microsoft Windows installation discs”
Source: https://support.apple.com/en-us/HT203973
anon(9602380)
5,828
Welcome to iMore.
If you insert an audio cd into your Mac, iTunes will open and ask if you want to add the music your iTunes library. It's as simple as that. Thanks.
DragelinaEt
