Do not disturb problem
stevencornish1
Aug 21, 2012
4
I am having a problem where my favourites lists calls are not getting through when do not disturb is turned on. I just get a missed call notification. My settings are correct and definately set to allow favourites. I have tried resetting my phone (hold the two buttons) but still no joy. Is anyone else experiencing this problem?
59,647
618
Mine actually works as advertised, although sometimes I wish it didn't. ;)
fubaracing7374
280
4
Look in Notification settings and then Do Not Disturb. You have to select what numbers you want to come through, it's not tied to your favorites.
Sent from my AT&T iPhone 5 using Tapatalk
Laelipoo
2,206
66
I am afraid I must disagree--it's definitely based on favorites.
iPhone 5 ✲ iPad 3 WiFi ✲ Macbook Pro running Lion 10.8.2 ✲ Xbox 360 ✲ Nintendo 3DS ✲ PS3
Beamed from a galaxy far, far away using Tapatalk!
Laelipoo
2,206
66
My settings are set exactly as above, but calls do not come through.
It must be a bug of some sort.
I would try a backup/restore/set up as new. If this fixes your problems, then you can resync your data. If not, just restore from the backup.
Remona94B9
