Differences and Comparisons between LockInfo, OpenNotifier and Notifier+ ?
briankeith513
316
7
18
Can anyone compare the differences in stability and capability between Lockinfo, OpenNotifier, and Notifier+ ? I'm sure many of us would appreciate that.
redbeard
1,001
33
Heard the dev is working on a new version. They're beta testing right now.
Yea you can get the beta in Cydia, it works perfect so far, no bugs and it runs real smooth, some cool new features have been added to it, I'm looking forward to the release..
Here is the beta repo: beta.notifiedapp.com/
yanks19
Jan 28, 2011
27
i'm using both Lockinfo and opennotifier. have access to all important appointments/messages/notifications and weather right on the lockscreen and the icons for the specific apps show in the status bar via opennotifier. with the addons available for ON, you can get icons for most of your push enabled apps. sure you can access lockinfo from the homescreen but i feel it should be left to just the lockscreen.
weblou
68
I use Lockinfo and notifier+... I live this combo.
Lockinfo only for lock screen and infoshade activated.
Notifier+ to stop all pop up's and get nice notification that do not interrupt me :)
Also use NotificationGrip
Jethro7
