Bizarre Iphone 5 problem. Desperate for a solution and Apple cannot solve it. Need help!
SillyPutti
Jul 19, 2013
I recently went camping and took tons of pictures. My phone ran completely dead, upon trying to turn it back on the screen turned completely red and froze. I rebooted it and it did the apple logo with writing at the top. I can reboot it but it ends up freezing or rebooting itself somewhere in the process before the lock or home screen. I can get it into recovery mode but my pc or mac doesn't recognize it when it's connected. I think I could factory reset it but that would lose these precious photos forever and I don't want to do this. After 45 minutes on the phone with Apple and hours scouring the internet and trying every option, there is no solution I or they have found. My question is is there any way to remove the "memory card" from the phone and access it any other way or in another iphone just to retrieve this particular photos. It is very important to me. Thanks for any help!
Teja Chillarige
Jul 19, 2013
Technically it is possible. However you would have to know about electronics, be familiar with circuitry and soldering, and have a working knowledge of apple's product designs. and even then, after removing the memory card it would be impossible to put the phone back together. Bottom line is, for you, it is not possible. I'm sorry, but you can basically say good bye to your photos.
rdiddy_25
3,419
9
1st, welcome to iMore. 2nd, the iPhone doesn't have a "memory card". Was your iPhone jailbroken? If so, you may be able to access them using iFunbox, or any other program like it. If not they may be gone forever. Sorry
finn5975
Banned
Sep 13, 2012
1,494
Just a shot in the dark, but did you have photo stream enabled? If so you could log into iCloud on your computer and recover them.
sting7k
3,011
62
Have you tried plugging it into the wall charger and walking away for 30 minutes? If the battery is completely dead it's worthless to try anything until it has some charge. It can take 10-20 minutes and it will reboot all on its own once the battery has some juice back.
anon(4698833)
Banned
Sep 7, 2010
12,010
187
If you have a mac available to you, try opening "Image Capture" and then plug the device in...many times it will be able to pull the stuff off the camera roll (if that is what you are trying to get) without all the checks required by iTunes to "recognize" the device. My nephews iPod was destroyed, but I was able to pull the pics and videos off of it with image capture (where iTunes would not recognize it).
scorpiodsu
945
Sorry to hear about the issue. Any Apple stores within a reasonable distance? If you can't get anything done on your computer, I would go to them before doing a reset to see if they have any additional "tricks". And for future, utilize photo stream, if not for anything else to avoid situations like this.
John Yester
Moderator Team Leader
May 23, 2012
8,847
I have had to do this a few times with clients devices and it worked better then iPhoto or iTunes.
59,875
669
That is exactly how I transfer the few photos I take with my iPhone to my MacBook other than uploading them to to cloud storage. It's simple, fast and effective.
vber
