Hi All,
Recently made the switch from Lumia 950XL to the iPhone 7 Plus (128Gb). Currently using a Nilkin H+ Pro tempered glass which is great quality, but leaves a noticeable gap between where it ends and the case, because it is flat and doesn't reach to the edge of the screen.
Are there any good tempered glass protectors that you guys can recommend me which are edge-to-edge and good quality?
