Best and/or cheapest way to rip DVDs for viewing on iPad
seabrook
Mar 17, 2012
7
Handbrake supported Sources:
?Most common multimedia files that libavformat and libavcodec support.
?Any DVD or Bluray-like source which is NOT copy-protected. (removal of copy protection is not supported)
Are most DVDs copy-protected??
The combination of Handbrake and VLC... fast, free and easy.
johndabeast
Mar 27, 2012
I was wondering this too, mostly for Blu-Rays, and Handbrake doesn't work well with Blu-Rays in my experience because, why wouldn't they have copy protection?
Peligro911
5,878
136
Hand break I could never get past copy protection .. And takes a awhile to encode ..
I use DVD fab you can encode to tons of formats and any iOS device also bypasses all copyright protection
I have used this even on Disney DVDs for my daughter
All these DVDs I owned just incase anyone is wondering
Fausty82
8,484
286
In my experience, the VLC program takes care of the copy protection. I don't have a blu-ray DVD player for my MacBook Pro, so I haven't ripped any blu-rays... but get and install the VLC app on your Mac, then Handbrake can easily rip your DVDs. They have a great forum that I have used once or twice for problem DVDs, but so far, I have been able to rip every DVD that I own....
In my experience, ripping takes about 20 minutes up to an hour per DVD... but the result is most excellent. And, for the record, I only rip the DVDs that I own... makes viewing them (especially for the grandkids movies) a painless and damage-free experience.
Fix HandBrake DVD ripping if you've installed VLC 2.0 | Macworld
hellomiggy
155
13
I've always used DVDFAB, it worked wonders and got over the copy-protected stuff. Never had a problem, always rented movies from netflix and copied em and sent em back. I SAID NOTHING! *delete's account*
Bias X
565
30
Handbrake does not come stock with the ability to get past copyrights.
In my experience Handbrake told me to download a extension that would allow it to break the copyrights on DVD's.
For the sake of not getting another warning about illegal things I won't tell you what it was. You can use google for that ;)
Fausty82
8,484
286
That is freaking WRONG... it's stealing, pirating and disgusting... no wonder the MPAA (and RIAA) are so anal about copy protection/piracy...
No members online now.
sunnyville01
