Battery usage by app not showing after battery replacemnt
mualhadi
Jul 11, 2014
Since i changed the battery on 6s the battery usage by apps isn't showing. There's just this message "Battery information will be available after using iPhone for a few minutes"
It's been a month since the replacement and i used the phone and done several complete battery cycles, Has anyone encountered this? and how i can get them to show?
The new battery performance is great though
boskib
Aug 9, 2015
Hi there, I have the same problem. Did you manage to fix yours by any chance? Thanks in advance.
golfinggod
Nov 26, 2016
19
I take it you've restarted the device and have the latest iOS installed? If so have you backed everything up and restored it? I'd try that before taking it into a store.
boskib
Aug 9, 2015
Probably won't go the store route at all - not a massive issue just bit annoying and looks to me software related. Will do restore all settings tonight an report back to you guys. :) Thanks.
Jdesutter
Jul 11, 2012
I have the same issue with the battery usage info missing after battery change and believe it is related to the new battery having a higher mAh capacity. I installed Battery Info (free app) and it says my battery wear is 0.0% and the capacity is 1800 mAh - not the standard 1715 mAh that Apple designed the phone to have. My usage detail returns as soon as I reinstall the original battery.
Ledsteplin
Oct 2, 2013
47,554
34
43
Try Reset All Settings first before you restore.
metalchick719
Mar 6, 2014
524
Odd. I just had my battery replaced on Friday and I'm not noticing this at all. Everything's showing normally under Battery for me.
