OK I just went to my local Apple store and got a screen protector and case for my new 13 Pro. what are your battery tips? Do I discharge every time? I’m at 58%. Do I charge at 50%. I know everyone has their own opinions
Keep it simple and charge the device when you think it’s needs charging. I charge my iPhone 13 Pro with its USB cable and charging block overnight every night.
I didn’t know with it being a new device if you should try to limit the charges or was that the old days. lol
Charge it when it needs charging. It's that simple.I don't use chargers rated over 20W.
It depends. It used to be 5W, now it’s 19 or 20W.What’s the wattage of the standard Apple charger
I would say so. But you don’t have to be precise to the minute. The feature learns your patterns on its own, so it will easily adjust to your charge “schedule”is it better to charge it the same time every day/night so your iPhone can “learn” according to optimized battery charging within settings
I would say so. But you don’t have to be precise to the minute. The feature learns your patterns on its own, so it will easily adjust to your charge “schedule”![]()
I just got my 13 Pro yesterday. should I be using the cord that it came with or does it really matter. does it say what wattage on the charging block on the bottom?
if you take a day or two off of charging is that OK for it
I charge my phone last night and this morning I’m at 96%. I know I might be paranoid but with this being a new phone (As of Dec 1) I want to get the most out of my battery. is that normal, I know phones don’t stay in 100% all the time lolView attachment 131535View attachment 131536
I’m planning on going to Texas for the weekend in about three weeks. is it better on your iPhone battery to use the wired charger or since I have a 13 Pro use the mag safe duo charger from Apple. I use a Belkin mag safe at my house but I was just wondering about travel
.I would cheffe the phone using a wired charger, for this simple reason: I want to be sure it is charged when I’m going to spend time outdoors and take pictures. The number of times my Qi charger decided not to charge the phone is sufficient for me to lose trust in it, the latest is… this morning.
