Battery problems? Don't think so ;)
chris3896
47
Not everyone has bad battery issues. I did for the first month. The update actually made it worse and then about two weeks after the update it got better. I went from 5-6 hours with limited use to about 12-14 hours.
hunoosh
188
7
I actually am starting to believe that if I just put the phone down, I may get a full day out of it. That may happen eventually. For now it's way too new and couple charges a day won't hurt me or my phone. :p
hoosieriphone
311
11
When I upgraded to 5.0.1 I could almost watch my battery drain right before my eyes. Literally LOL. Well, I did a restore as new after doing a backup. Now after doing some heavy surfing and some texting for 8 hrs or so, I would be down to 60-65%. I am very pleased with the battery now.
Rockdog97
1,514
22
I've contemplated doing the restore as new, but it seems like a hassle to have to reload everything. I know I can do a back up, but I guess my main concerns are:
-backup of Kindle books that i've downloaded directly onto my phone (non iTunes books)- don't see a way to back these up with either iTunes or any other means.
-reloading all my apps that i've downloaded - do I need to re-download these from the App store or will they get transferred back via iTunes?
-email, contacts and calendar are all backed up using Google, so I'm not worried there. Reminders and Notes are backed up using iCloud.
-browsers such as Atomic - will the bookmarks that I've saved be kept with the program or be deleted?
I think it just may be worth it for me to wait for 5.0.2, or even 5.1... my battery life isn't terrible, so i'm not really in desperate need of better battery life.
Cleveland
1,447
72
48
I did and then let iCloud do it's thing and mines been great since
  • Like
Reactions: Rockdog97
Designed4Him
612
5
I'm like you I think if I put the phone down I will get more battery life. My usage and standby time are always the same.
Sent from HIS WORLD on my iPhone 4S using Tapatalk
morrow95
Nov 3, 2011
31
Originally my battery was horrible as I could literally watch it drain. I upgraded to 5.0.1, turned off the data and usage sending, let the battery go down to basically nothing, then did a full charge... ever since that I have had pretty decent battery life and a noticeable difference.
durtress
Nov 5, 2011
4
I call BS. Unless you don't use the phone at all it wont last 2 days.
On Thanksgiving day I did not use the phone at all. It just sat there for 5-6 hours. When I checked the battery was down to 63%.
Even my old BB Storm wasn't that bad
sunnyville01
