Battery not performing as well on iOS 11
popkurn611
Nov 13, 2016
1,001
Anyone else experiencing a deplete in battery life? Hoping it would take a few days to settle in on the new os but was getting much better battery life on iOS 10
58,162
229
63
Using my iPhone 7 Plus, I got great battery life running iOS 11, but I’m in the process of giving it to my youngest son. Right now, I’m using my brand new iPhone 8, but I can’t say anything in regard to it battery life yet.
nikkisharif
Jun 2, 2011
8,516
Haven’t had an issue with battery life on iOS 11. Have you tried rebooting your device or resetting network settings to see if that helps?
TripleOne
Trusted Member
Oct 4, 2014
9,333
The battery life on my 7 Plus running iOS 11 seemed normal.
No issues at all here.
rumpelst
Sep 16, 2016
27
You need to wait Popkurn. After update you can have worse battery life due to cleaning and indexing you system perform. It should last no longer than couple days.
popkurn611
Nov 13, 2016
1,001
I said I was hoping it would take only a couple of days to settle in. It’s been more than that. My battery isn’t draining just not as good life as I was getting on iOS 10.
popkurn611
Nov 13, 2016
1,001
I’ve done a reboot but haven’t reset network settings yet. Guess I can try that
CyreneK
Aug 5, 2016
134
According to posts on Google+, battery life has been horrible for most. Including my iPhone 7’s (x3). My daughter is begging for the 8 now because of it. Lol
TripleOne
Trusted Member
Oct 4, 2014
9,333
iOS 11.0.1 is out, hopefully it’ll fix the problem!
Nubwy
Apr 23, 2015
110
I got the incremental update and tbh battery has settled down a bit. Still lasts all day for me.
Phill_UK
Oct 6, 2012
347
I’m not finding iOS 11 too bad for battery life on my 7.
This was today’s usage running 11.1 beta 2...
