Battery life drain since IOS 11
boeber
Dec 17, 2017
6
How to resolve these issues, because i replaced my battery and it’s still has 0% wear.
In IOS 10 I was getting 1 hour and 16 mins of usage for the first 10%, with IOS 11 I’m getting 47 mins of usage. (Background app refresh and location is turned off as well as a low brightness is applied)
Solutions please
B.
60,410
882
That’s impossible due to the fact that I replaced my battery
How is it “impossible” and what does replacing your battery has to do with it? After replacing the battery, did you reset all settings? Have you taken the time to allow the battery to completely drain or drain to less than 5% and then charge uninterrupted to 100%?
boeber
Dec 17, 2017
6
Bruv, i wiped my phone immediately after I had it fitted in. Straight after that I restored all my data back onto my device and charged to 100%. I completely drained the battery to recalibrate it. So now smart ***, explain yourself, because i spoke to an iPhone specialist who explained to me by saying that there was an issue initially with battery life by updating your device to IOS 11, but 11.2 suppose to fix those bugs. So.. talk to me
He also told me the battery life suppose to be better than a 6s
60,410
882
For me asking a question, you want to call me a smart arse. Wow. Okay. Anyway, If the new battery is NOT getting better battery life in your opinion then there's really nothing else for me to suggest. Hopefully, battery life will improve for you after a few days of use. Take care.
boeber
Dec 17, 2017
6
For me asking a question, you want to call me a smart arse. Wow. Okay. Anyway, If the new battery is NOT getting better better life in your opinion then there's really nothing else for me to suggest. Hopefully, battery life will improve for you after a few days of use. Take care.
Shot.
