Battery issues after updating to IOS 10
pinorally
Aug 22, 2012
18
Ok so my phone dies as soon as It go down to 50% of battery. My iPhone 6 is 2 years old, could this be the problem? Any help will be very appreciated!
Jeroen7
236
Was this only after the iOS10 update?
Sometimes a new os needs to settle in, try to do a full charge to initiallize the battery percentage.
Jeroen7
236
Maybe try a full discharge then? Even if it shuts down, just restart and see if it still works.
Have you got the battery percentage showing?
And maybe a factory reset could help? After two years that can give your phone an extra boost again in performance.
pinorally
Aug 22, 2012
18
Yes I got the battery percentage, but often doesn't show the real percentage...very strange. Not comfortable with a factory reset, I am scared something could go wrong. I am tempted to buy a new battery...
Jeroen7
236
I don't think it's battery related, but software.
I know it might be scary to do a reset, but with most things being in the cloud, if you work with iCloud. You won't loose data. Only setting up stuff again tales a bit of time.
Maybe first contact apple support about this to see what they say. Else you might unnecessary spend money.
bigtruck1369
56
I've been having somewhat similar issues, my 6 often dies at 30-40%. I had an authorized Service place run on a test on mine and the battery was still rated at a high 80%, so I'm guess it's software related. I'd restore my phone but I've got some things going at the moment where I really need it. It is getting tiresome only having a phone that lasts a few hours of use.
janinv23
