Battery drain with Parallax effect in iOS 8?
Skippy
72
ello,
I'm a battery saver freak, disable most battery-draining feature that is possible, always close apps from the app switcher and so on. I'm coming from iOS 6 to iOS 8, which has the Parallax effect feature. It was introduced in iOS 7 but people said that it drained your battery somewhat. I did turn it off partially because I don't want my icons "floating" on the homescreen and to save some extra battery life. But what I dislike is that with having the Parallax effect off it also affects the animation when opening/closing an app, unlocking/putting phone to sleep really awfully.
So now finally to my question, have people already done some research if they have improved the way it works to not drain battery as much or is it gonna be a "Either you live with it, or don't" kind of thing? Really wished that atleast they could have seperated the animation and the floating icons feature but I'm stuck having to live with both floating icons and battery drain? :(
59,758
641
I don't know, but I haven't read any posts about it draining the battery when enabled.
Skippy
72
Really dislike the choppy and unnatural animations so I guess I'll have to try and live it even though it really hurts my battery-heart everytime I see the damn icons move. Hopefully such an options becomes (after a certain kind of break) available where I atleast could separate the Parallax and the animation.
Squillace
Jan 5, 2014
6
When you set up a wallpaper (for lockscreen or the Springboard, it doesn't matter), there is a button to turn Motion ON or OFF, which is going to enable or disable the parallax effect.
Just like this:
I'm pretty sure this option was introduced in iOS 7.1 and I believe it won't mess with the animations.
Why don't you give it a try?
Skippy
72
Just like this:
Where the motion button is on your screenshot it says "Perspective" on my 6 when I go there.
Ledsteplin
Oct 2, 2013
50,237
706
108
settings>General>Accessibility>Reduce Motion Turn off to use Parallax. Turn on to not use Parallax.
Sent from my ancient but trustworthy iPhone 5
