Anyway for Auto-Lock to only apply while on battery?
muzicman82
Jul 13, 2009
8
Hello,
I'd like to know if there is a hack or utility app that can setup the phone so that the display stays always-on while the phone is attached to external power. So, the only time it turns the screen off automatically (and locks) is when you're on battery.
An example when this would be useful is when in a vehicle using the phone for GPS functions.
Ideas?
fleury
Jun 29, 2009
37
jsut head into your settings then general. put auto lock on never. i love it that way. great for gps and downloading!
muzicman82
Jul 13, 2009
8
Well I understand that function, but then it won't auto-lock when on battery, which would likely drain the battery if it was not manually locked, correct?
fleury
Jun 29, 2009
37
oh ok I'm sorry. but yea you would have to lock it. i have mine set up that way and i really love it. i am not aware of a program that would do what you want but i never looked so it could be out there. sorry i was not able to help you out though.
muzicman82
Jul 13, 2009
8
Thanks... this new iPhone 3GS isn't actually mine. I'm a Windows Mobile junkie (HTC Touch Pro, which I love), and all Windows Mobile devices have separate settings for battery and external power. I'm kind of shocked the iPhone doesn't.
They'll probably add it in iPhone OS 4 and call it "revolutionary".
Hopefully someone's got a hack somewhere...
temp.wazeer
