6 plus vs 6s plus battery
jianrong
349
Im on 64gb. How much improvement? Mine current usage battery life as shown.
anon(4698833)
Banned
Sep 7, 2010
12,010
187
Mine is around the same to slightly better...averaging between 10-12 hours on a full charge (usage time). Totally satisfied with that, especially since I do a lot more with this phone than I did on the previous model (including using "Hey Siri" all the time and the 3D Touch feature is becoming more and more useful, which i think actually helps with battery life since it gives so many shortcuts).
1901Madison1
Sep 20, 2014
13
Yeah I'd say sheesh that is amazing battery life good luck getting anything close to that with an Android phone.
Here's mine very happy with it!
//images.tapatalk-cdn.com/15/10/05/1a407c1285e4c199fe2239b30aa03222.jpg
The Lannisters send their regards
Some Android phones can beat that. Not many, but I have a 6+ and a Droid Turbo. The Turbo simply does not die. I can really get 10+ hours of screen time (screen time, not usage). And that is with auto brightness.
Jde2466
Sep 12, 2015
16
Here is my battery life. Took it off the charger at 7:30am and at 4:30pm I am at 20%. Today has not been a really heavy use day. My Note 4 had similar battery life. I don't see how most of you are getting super long battery life. Maybe I use mine more?
Michol Kim
91
Lets not kid ourselves here. Apple dropped the ball on the battery for the 6s plus.
6s plus 2750 mah vs 6 plus 2910 mah.
its's even worse on the 6s
1715 mah vs 1810 mah.
Apple can spin it and say 6s models has better power effeciency, processor, etc and so forth but NUMBERS do not lie.
Cutting back 95 mah on the 6s series battery makes 6 plus battery better.
Michol Kim
91
What does the engadget article have to do with this topic? It's 6s plus battery vs 6 plus battery. Not 6s plus battery vs Samdung?
Spencerdl
Apple Watch Champion
Jan 10, 2013
41,139
208
63
It's my experience while owning both the 6 Plus and the 6s Plus, there about the same...To close to say one is better than the other. Both have EXCELLENT battery life IMHO
LCW
1,468
8
You clearly didn't read the article. Two different CPUs are used for 6S/6S+. Apparently one of them provides markedly longer battery life. One CPU made by TSMC, the other by Samsung.
Blin
