Welcome to the all-new iMore Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
My iPhone 4S battery has been draining at an alarming rate, even when not in use. I've turned off all apps, updated the software and even restored it this morning. Nothing has worked. Does anyone have any ideas on how to fix this?
Thanks!
Kevin
Aslo another suggestion would be to remember the last few apps you've installed. something could have gone wonky and a delete/reinstall of the app may be needed as well. After doing that, if theres still a rapid drain, delete the app completely and see if it still occurs. narrowing it down to a possible app as the colprite could be a royal PITA tho.
another 2 suggestions if you havent already done them: reset all settings AND reset network settings.
When you restored your phone, did you restore as new not using your back up? If you've done that plus everything else already and haven't seen a change, then yes, I'd say time for a genius bar apptThis is a real doozy! I've tried everything I can think of. Restored my phone. Turned off WiFi, Location Services and all my apps. Deleted my most recent installed app. Putting it in Airplane Mode helped, so I don't think it's my battery. I can't think of what else would be draining it. Time to go to the Apple store?
Ok, the reason of restoring as new and not using your back up is to determine if your devices battery is still draining like crazy without apps etc. on it. The only thing I would say to put back on your device after setting it up as completely new is to have iCloud sync ONLY your contacts and calendar, reminders, notes. I would not put anything back on right away just so you can see how your device behaves with the minimal things on it. IF with just the minimum your still seeing that huge battery drain, then definately go to the genius bar. IF you don't see a drastic drain, then that means there is something within your complete back up that is the culprit, and you'd have to try and figure out whats causing it.No - I restored using my backup. If I restore as new, can I still sync all of the backup data (messages, photos, etc) I have in backup?
