3gs will not charge after screen replacement
TxTj97
Oct 20, 2011
4
Replaced glass digitizer on 3gs with success. Everything worked correctly until the next day, had 8% battery and could not charge or connect to itunes. Removed digitizer and checked ribbon connectors and still not luck. Tried to do hard reset but not enough battery to boot up.
Does anyone have any suggestions or ideas on where i should look next? Bad charging port? Blown Fuse? The phone did work correctly after the screen swap!!
TxTj97
Oct 20, 2011
4
charging port
Do you know if the charging port for a 3g is compatible with the 3gs?
