1. nokia4life's Avatar
    Hi everyone i am looking for some help so i have a 27inch samsung LED HD Monitor and it works fine with my work laptop however when i plug the hdmi cable into the my macbook nothing displays but a gray screen i can't see anything. Is this normal the macbook pro that i have has a HDMI port so why would this not work thanks for your help in advance....
    10-17-2013 12:03 AM
  2. Chris Parsons's Avatar
    There's several things that could be at play here.. the least of which the monitor being incompatible.
    • Have you rebooted the MacBook while the HDMI cable was plugged in? Sometimes that's all it takes
    • Have you checked the display settings? When you plug it in you should still be able to see the display on your MacBook, go to Settings and see what it says or if it is even finding the Samsung display
    • Try hitting Command & F1 together. This will mirror the displays in which case, both should flicker a bit indicating it's being detected
    • Bit of a daft question but have you checked the HDMI cable as well to ensure it's properly working?
    • Do you have any apps running in fullscreen when you try to connect? If so, stop running them full screen
    nokia4life likes this.
    10-17-2013 12:12 AM
  3. Fausty82's Avatar
    Mine works. I just tested with a 32" Sony Bravia television. As soon as I plugged in the HDMI cable, I saw the display mirrored on the tv. I didn’t have to change any settings at all.
    10-17-2013 12:13 AM
  4. nokia4life's Avatar
    Thanks I will give this a try i did not do a reboot since it didn't have to with my other laptop which is a lenovo for work. I will let you know if works.
    10-17-2013 12:21 AM
  5. Chris Parsons's Avatar
    Yeah and really, you shouldn't have to but sometimes it gets buggered up in the detection.
    10-18-2013 12:54 AM
Similar Threads
  1. Cannot communicate with server...
    By Godsdragon in forum iPad mini Series
    Last Post: 07-11-2014, 12:48 PM
  2. RoboMouse HD--really cool and addictive tower defense game
    By longkoogames in forum iPhone Apps & Games
    Last Post: 12-24-2013, 01:19 AM
  3. Help with girlfriends stolen iPhone 4s
    By Bold_until_Hybrid_Comes in forum iPhone 4S
    Last Post: 10-28-2013, 04:45 PM
  4. How to schedule appointment with Siri on a specific date?
    Last Post: 10-16-2013, 09:11 PM
  5. Mac Pro Release Date
    By James Falconer in forum Mac Pro
    Last Post: 10-16-2013, 02:26 PM
