The iPhone Pro Max Wallpaper Thread
Spencerdl
Apple Watch Champion
Jan 10, 2013
41,122
193
63
Thank you D
I had to work a little magic but I got’er done
Here ya go !
THANKS for the MAGIC PINK
ThePinkChameleon
Trusted Member
Jul 8, 2011
10,872
482
83
Here’s a wall I made. Pink snow background is from Pinterest, and the stickers are from an app I use called Pic Collage. (I have the premium subscription to get all the extras)
hope you all enjoy it ! Guys I will find something to create for you too
Haikal Putra
Oct 6, 2018
5
@Ledsteplin can i know is there an issue with iOS 13 that made it why it would not automatically be in the position for wallpapers with border? Previously on my iPhone X, it was automatically in the exact position of the screen to match the borders but now on the 11 Pro Max, it would not. Are there any ways you could make it back like how it was like last time? Appreciate your reply. Thanks Led!
Ledsteplin
Oct 2, 2013
50,283
710
108
Yes, iOS 13 has made it where the older bordered wallpapers don't fit. The newer ones I've been posting should fit. I got them from Hideaki Nakatani's site.
https://heyeased.weebly.com/border-wallpapers.html
Those you had for your iPhone X will not fit the XS MAX. None of the old ones fit without adjusting them. The new ones should be OK, but I don't know for sure, as I don't have the Max iPhone. I use the 6s Plus.
williams77
