Here's a cloud one you might like for your X.
//uploads.tapatalk-cdn.com/20190206/28a675757a42aaa735df75002ffa0d56.jpg
HI there, anyone of the Veterans here, who can assist me with the colour of this wallpaper
I would love a light Pink, Grey and maybe white if it's possible at all ?
Can it be done, so that it's more of a light pink cammo than the blue or grey ?
Thanks a stack !!
I did a quick Pinterest search and found this 1st camo wall. The 2nd from a google search. Maybe one of them will work for you till someone may be able to edit the one you posted.
//uploads.tapatalk-cdn.com/20190215/108981622e6a539a6e00dc1bab34791f.jpg
//uploads.tapatalk-cdn.com/20190215/c38e8a6b0bba3b778b00e4b9a8a689aa.jpg
The 2nd one from google does have water marks but they are extremely small if you’re able to look past it.
Thanks. But I love the cammo pic I posted. Just wanted it in pink .. I know there are some wizards here with photoshop
Ok np ! I figured I’d try to find something similar to hold you over till someone can edit the one you posted
Thanks a stack !!
Can someone center this? So that the time is visible? //uploads.tapatalk-cdn.com/20190214/5b1f7a75365d1cf9a40c493ce59cb52a.jpg//uploads.tapatalk-cdn.com/20190214/67de8836a65f7c288a9b28f916642d4f.jpg
