1. Ledsteplin's Avatar
    Good morning. Can someone please resize to fit iPhone 11 Pro Max?
    [IMG=1080x1920]https://uploads.tapatalk-cdn.com/20191202/db3b22bbae98213a56fb573d283f4e37.jpg[/url][IMG=1440x2560]https://uploads.tapatalk-cdn.com/20191202/de1ff55842dfd196ea5b9cd487e07913.jpg[/url]
    12-02-2019 02:53 PM
  2. taeisme's Avatar
    [IMG=947x2048]https://uploads.tapatalk-cdn.com/20191202/4c77e86198fcce0ce2a21280939bae24.jpg[/url]
    [IMG=947x2048]https://uploads.tapatalk-cdn.com/20191202/c20aad45be49e4ed849392ee35d5ab7e.jpg[/url]
    Thank you so much!
    absb and Ledsteplin like this.
    12-02-2019 05:19 PM
  3. Spencerdl's Avatar
    12-02-2019 09:45 PM
  4. Ledsteplin's Avatar
    Thank you so much!
    Do they fit along the sides ok?
    12-03-2019 08:54 AM
  5. Spencerdl's Avatar
    Yes
    Ledsteplin likes this.
    12-03-2019 08:57 AM
  6. Spencerdl's Avatar
    12-04-2019 10:47 AM
  7. Nonsenseinsd8's Avatar
    12-04-2019 10:53 PM
  8. Ledsteplin's Avatar
    https://uploads.tapatalk-cdn.com/201...5aeb7778.plist
    [IMG=1080x2340]https://uploads.tapatalk-cdn.com/20191204/d66d1ca5b6e6f460fac98b6898cd4be6.png[/url]
    Wonder why that first one is upside down. Alan's watermark is usually at the bottom. Wish he wouldn't put his watermark on wallpapers!
    12-06-2019 01:14 PM
  9. Ecm's Avatar
    In that location, the weatermark will be right in the middle of the notch. Problem solved?
    Spencerdl likes this.
    12-06-2019 01:17 PM
  10. Spencerdl's Avatar
    Because I turned it upside down. I like it better that way, "why, ya gotta problem wit tat"
    12-06-2019 01:36 PM
  11. Ledsteplin's Avatar
    Nope. Just don't like him putting a watermark on wallpapers. Your notch should cover it at the top.
    12-06-2019 05:38 PM
  12. ivanwi11iams's Avatar
    Credit where credit is due, and all that...
    12-06-2019 09:08 PM
  13. Haikal Putra's Avatar
    Thanks @Ledsteplin for your kind explanation. Seems like even the newer ones have to be adjusted to get the right fitting unlike how it was last time whereby it just works... and making adjustments at times made me grumpy cos sometimes its just not accurate here & there. Nevertheless hope we could see it work as how it was like the iPhone X era.
    Thanks Led 🤝🙏🏼
    12-07-2019 01:59 AM
  14. Spencerdl's Avatar
    Thanks Led
    Does it have anything to do with the fact that the Xs Max and Max Pro screens are larger than the X, which is closer to the 6s Plus screen size? I'm not sure but this might have something to do with it. The "trimming" wallpapers never fit my Xs Max either.
    12-07-2019 02:44 PM
  15. Spencerdl's Avatar
    12-07-2019 09:38 PM
  16. ladyc0524's Avatar
    Courtesy of AR72014
    12-08-2019 08:02 AM
  17. ladyc0524's Avatar
    12-08-2019 08:09 AM
  18. Ledsteplin's Avatar
    12-08-2019 10:36 AM
  19. Ledsteplin's Avatar
    12-08-2019 02:22 PM
  20. Ledsteplin's Avatar
    12-10-2019 09:53 AM
  21. Spencerdl's Avatar
    12-10-2019 10:33 AM
  22. Ledsteplin's Avatar
    12-10-2019 04:28 PM
  23. Ledsteplin's Avatar
    @TLD1
    Taylor guitar
    Seneca09 likes this.
    12-11-2019 08:25 AM
  24. Ledsteplin's Avatar
    12-11-2019 11:51 PM
  25. Ledsteplin's Avatar
    12-12-2019 03:13 PM
1,024 ... 3738394041
Similar Threads
  1. Post picture(s) taken with your iPhone XS Here!
    By Almeuit in forum iPhone XS
    Last Post: 09-13-2019, 05:47 AM
  2. XS Max battery blows away the top Android phones
    By briareos4 in forum iPhone XS Max
    Last Post: 09-27-2018, 10:14 AM
  3. Does the XS MAX offer better battery life then the XS
    By lolmit in forum Ask a Question
    Last Post: 09-22-2018, 01:28 PM
