Keyboard click sound lower than send sound
unity04
55
I've noticed that when typing out a text message that the clicking sound on my keyboard is a lot lower than the actual sending swoosh sound. Is there a way to adjust the volume for the keyboard? It doesn't seem like I can find it anywhere in the settings.
59,784
645
If you're running iOS 9 then yes, the keyboard click sound does appear to be lower than in previous iOS versions. Having said that, the volume control keys can control the volume of the keyboard click, but even at the maximum level, the sound is low, in my opinion.
jayk82
Trusted Member
Aug 25, 2013
344
I've experienced this as well. Also searching for some help / an answer regarding this.
Sent from my iPad Air 2 using Tapatalk
smitty22d2
