The plus has a bigger battery and last longer. the 6s would be out of juice towards the end of the day while the plus consistently lasts about a day and a half (on my normal usage) your mileage may vary. The flip side is that the plus is very slow to charge when using the included 5w charger
Can the 6s+ be charged with a stronger charger than the original one without badly affecting the battery?
Posted via the iMore App for Android
yes you can use apple 12W with no issue
And that will not badly affect the life span of the battery?
