1. Ankush Pandey's Avatar
    So, i ordered an iphone 6 battery from amazon and replaced it properly without any damage.
    Everything went perfectly but after a few days the battery started draining VERY fast. It loses about 50% in an hour.
    I checked the battery capacity using different tools and they all say that battery is at 100% capacity.
    I even did the geekbench test to see the performance and the performance increased to the new iphone 6 level.
    I'm currently running ios 11.2.6.
    Tried everything from calibration to complete restore. Nothing works!
    What to do?
    PS: Also, I'm not able to see the battery usage statistics since replacement.
    03-07-2018 09:29 AM
  2. Just_Me_D's Avatar
    Either reset all settings or restore your device and then set it up as new.
    03-07-2018 10:39 AM
  3. Ankush Pandey's Avatar
    Already done it. Nothing!
    03-07-2018 11:07 AM
  4. Garz's Avatar
    Maybe because it’s a battery from amazon?
    Ledsteplin likes this.
    03-07-2018 12:33 PM
  5. Ankush Pandey's Avatar
    but upon checking it says the battery has 100% capacity.
    Does that not mean the battery is fine?
    03-07-2018 01:44 PM
  6. Ledsteplin's Avatar
    There's not really any way to see your % capacity, or battery health, in an app. Apple no longer offers that info to developers. So it's probably not that accurate. They're guessing using whatever they can. Try swiping out battery hog apps in multitasking, then a hard reset (reboot).
    I read a review on Amazon, where someone purchased a new battery, then checked the charge cycles. It showed over 250 cycles had been completed.
    03-07-2018 02:21 PM
Similar Threads
  1. What is the best VR Headset for iPhone?
    By pkcable in forum VR & AR Lounge
    Last Post: 05-23-2018, 10:13 AM
  2. Replies: 5
    Last Post: 03-09-2018, 09:37 PM
  3. iPhone X crackling over FaceTime/calls
    By atarinerd93 in forum iPhone X
    Last Post: 03-06-2018, 02:19 PM
  4. Best trivia games for iPhone and iPad
    Last Post: 03-06-2018, 12:10 PM
  5. Best apps for filing your taxes right on your iPhone or iPad
    Last Post: 03-06-2018, 10:10 AM
