iPhone 6 with BT audio problem
I am experiencing and issue that seems to be software related at the OS layer not the App layer. This happens in both the Apple music app and Pandora. As well as being intermittent it is not BT device specific.
I will be listening to audio in one of the mentioned apps and the volume will go down considerably for no reason or action. What makes this real strange is that if I receive a text or email or any notification once that tone ends my volume will be back to where it is supposed to be.
This happens every time. I think it is an OS issue but wondering if anyone else has had this.
Re: iPhone 6 with BT audio problem
I'm not so sure that's a bug... It's supposed to do that... So you get/don't miss the notification.
