1. sharon cesca's Avatar
    I phone will not hold charge and the icon up in right corner is white shouldn't it be green when fully charged
    04-03-2014 10:47 AM
  2. sharon cesca's Avatar
    Are you guys there or not??????
    04-03-2014 10:48 AM
  3. geezio's Avatar
    When it's plugged in for charge it's green and with certain apps ,on the 7.1 IOS it's always white otherwise!
    04-03-2014 11:07 AM
  4. Jrome.brooks's Avatar
    Sync your iphone to your. Computer, backup erase everything and start new
    Sent from my gold 5s using Tapatalk
    04-03-2014 01:22 PM
  5. kataran's Avatar
    It will show a lighting bolt beside the battery icon when charging you will hear a sound if enabled when you plug it in
    Green is for fully charged
    You can enable the percentage by going to Settings>General>Usage and tap to turn on battery percentage that will show you how much charge you have left
    iMore Ambassador -iPhone 5s
    04-03-2014 01:34 PM
  6. kataran's Avatar
    Sorry For the delay Sharon it was around lunch time
    By the way Welcome to iMore 😃
    04-03-2014 01:37 PM
  7. kataran's Avatar
    I also see you mentioned a charging problem is this a fact?
    04-03-2014 01:39 PM
  8. EmceeGeek's Avatar
    It's green only when on the phone is charging. As far as your battery not holding a charge you need to take your phone to the nearest apple store so that they can give you a new one.
    Oh excuse us
    Sent from my [Gold] iPhone 5S
    kataran likes this.
    04-03-2014 09:36 PM
Similar Threads
  1. If You Are A Forum Member - Do You Read The Blog For Info? Yes Or No?
    By Jaguarr40 in forum iMore.com News Discussion & Contests
    Last Post: 04-05-2014, 09:42 AM
