Anyone with sound problems? Please help
Arturo Ortiz
Jan 29, 2012
I'm having problems with music sounds in my iPhone 4: either on the docking station or with headphones, only one channel will sound and the other remains completely mute. I have already tried with several headphones and docks. Always the same: only one channel is working!!!
I went to an authorized dealer and they don't have a clue.:(
Should I try a master reset?
Thank you very much for your help.
Engire
49
8
Try this:
Setting---General---Accessibility
Scroll down and you will see some settings about sound, there is a balance slide that might be to one side or the other.
  • Like
Reactions: Arturo Ortiz
elitegamer767
47
Hold power button and home button together for 10 seconds if this doesnt work it could be your actual dock on the phone where the charger plugs into might need a clean with a thin small firm paintbrush
Sent from my ? iPhone 4S using Tapatalk ?
Arturo Ortiz
Jan 29, 2012
Try this:
Great!!! That worked!!! It was 100% on one channel!!! Big thanks man!!
Regards from freezing Belgium
Arturo
smitty22d2
