1. treouserinla2's Avatar
    Hi! I was hoping somebody here might be able to help me.
    I have a jailbroken and unlocked 3G iPhone and have been successfully using my T-Mobile T-Zones plan on Edge. Now, out of the blue, it doesn't seem to work. I see the "E" saying it's on Edge, but Safari says it cannot connect to the Internet.
    Any advice?
    By the way, just to let you know, I have been using the T-Zones hack for months now and everything was working fine. Since this problem has occurred yesterday I did some research and changed the APN settings to see if that would help. (I changed it from wap.voicestream.net to epc.tmobile.com, I believe.) Unfortunately, it did not help. Is there a different setting that I've messed with and need to change back?
    Any help would be appreciated. Thanks!
    05-25-2009 06:47 PM
  2. treouserinla2's Avatar
    WORKING NOW! :-)
    It turns out it was a problem with SBSettings. For some reason, it was blocking Edge somehow. I reset SBSettings, removed the Edge settings from the pop-up control window and everything is back to normal. Strange.
    Anyway, maybe this little post will come in handy for somebody in the future.
    05-25-2009 07:01 PM
  3. rgspencer's Avatar
    What are sbsettings? I"m having this problem too.
    06-11-2009 09:16 PM
