1. VWilliamm's Avatar
    Hello
    I returned my last iPhone 11 Pro Max after it was making a clicking noise in the middle of the screen and near the Apple logo when I pressed softly.
    I got a brand new iPhone 11 Pro Max today after waiting 3 weeks on this because it was out of stock. However, its doing exactly the same sound. This time even worse, the screen is popping and making a clicking sound in the middle of the phone when I press softly.
    Do you guys have problem with this? This is my second time with the iPhone 11 Pro Max. I have called Apple again, and they will send a new one. However, if the third one is doing the same I am done with Apple.
    Anyone having this issue as well?
    07-21-2020 04:10 AM
  2. mach1man's Avatar
    Hello
    I had this same issue when the 11 pro max first came out. I went to an apple store and had it swapped out. Didn't really have the issue after that. They said it could've been the wireless charging magnet coming loose. If you can go to an Apple store I would recommend that.
    07-21-2020 08:48 AM
  3. Garz's Avatar
    I need to go to Genius Bar for a separate issue. Problem every Apple store in my state and most surrounding states is closed. It’s not so easy these days for that.
    07-21-2020 11:42 AM
  4. kataran's Avatar
    Hello
    Welcome to iMore
    The third one will be a charm so enjoy your device and Post Often if you can
    07-27-2020 11:56 AM
Similar Threads
  1. Iphone 6 Battery/Reboot Loop
    By Stanhauser in forum Ask a Question
    Last Post: 07-22-2020, 08:04 PM
  2. Replies: 3
    Last Post: 07-22-2020, 03:07 AM
  3. Over 26% of iPhone SE customers came from an Android phone
    Last Post: 07-20-2020, 05:12 PM
  4. iPhone 12 will support sub-6GHz and mmWave, but not the iPhone 13
    Last Post: 07-20-2020, 04:40 PM
  5. iMessages deleted from my iPhone.
    By serenty178 in forum iMessage
    Last Post: 07-20-2020, 04:16 PM
