Cladster
I’ve been watching a lot of video I. The Note 20 Ultra. May not be rubbish this year.
Was referring to finger print scanner, and it will be rubbish.
Calling it rubbish is rather kind, it just never worked.
The s20 flopped earlier this year, don’t think the note 20 is going to do any better.
Yeah, and it’s amazing people buy it with a major feature that just doesn’t work.
Personally, I like the fingerprint sensor better than Face ID. Even more so since the mask mandates. Which pretty much renders Face ID useless.
sure on a iPhone, doesn't work on a samsung hardly.
I am referring to in screen finger print readers. Way better than Face ID
Only if if actually works, the ultrasonic FPS not so much. Having said that, it is pretty much useless when wearing protective gloves.
You're really reaching. Fortunately,"protective glove" wear isn't being enforced,so that's a non-issue. Damn near everyone is wearing masks, No one is wearing gloves.
I keep hearing “it’s useless”. I guess my wife and daughter have the magic thumb because it works spot on. No hesitation or anything.
Nonsense.
Some wear face masks, some wear gloves, some both.
It’s much easier to pull down a mask for a second then it is to take off a glove and then put it back on.
Yes users keep saying “it’s useless” or “it’s rubbish”and it seems to be the second biggest complaint, after the exynos soc.
Most just switch it off.
Your point is moot, because nobody is wearing gloves.
The problem is your blind commitment to Apple. Unlike you, I use iPhones,Samsung, and Google Pixels.
. And with this pandemic, Face ID IS AN ISSUE. So much of an issue that Apple had to issue an update for the mask use to try to make it somewhat less annoying albeit still annoying. Before the update, I left my iPhone on the shelf. Since the update I do use it more,but Face ID still sucks.
https://www.macworld.com/article/3545476/apple-face-id-mask-android-smart-lock-auto-unlock.html
Your point is moot, because nobody is wearing gloves. The problem is your blind commitment to Apple. Unlike you, I use iPhones,Samsung, and Google Pixels. And with this pandemic, Face ID IS AN ISSUE. So much of an issue that Apple had to issue an update for the mask use to try to make it somewhat less annoying albeit still annoying. Before the update, I left my iPhone on the shelf. Since the update I do use it more,but Face ID still sucks.
And pray tell, what do the last few messages have to do anything with keeping an iPhone 11 Max?
Please stay on topic or create your own thread to bikker about touchID vs faceID.
You can start by addressing the perpetrator,which was not me.
