Originally Posted by
flyinion The glass is normal. The top part is cut out to ensure there are no issues with the sensors, though not all protectors do that. My ESR protectors that I use used to cut out for the X and they changed their design at some point to cover all but have a gap for the ear speaker. As far as not going to the edge all the way around, that's because the screen curves and it's hard to get a glass screen protector to cover that. There are companies making "3D" curved protectors (usually have a black border on those areas) but they also are usually only guaranteed to work if you use them with a case from the same company as other cases might intrude into the area and cause the protector to lift up. There is a small chance of scratching on those exposed areas but much less than if there is nothing there. Mostly it just becomes an area to accumulate dust/lint.
The issue with the ear speaker that shine with light another user who commented says it’s normal but who knows.
According to me I think Apple replacement devices use different parts then the retail unit.
