OK so I have the iphone 11 128GB but I'm looking at getting the pro max.
but the first thing is the storage, I would have to get 64GB which I don't think will be a problem
in checking storage I'm using only about 13GB of the 128 so I think i will be OK? but will try and bring over music from google?
if you can do that. if not not a big deal. I was told the pro had 4 antenna over the two on the 11
any thoughts
thanks
any thoughts
thanks
