1. strikeIII's Avatar
    Is there a better Alarm App that will override the ringer volume and always be at Max volume?
    10-13-2019 08:09 PM
  2. o4liberty's Avatar
    Try this one from the App Store
    strikeIII likes this.
    10-14-2019 09:27 AM
  3. strikeIII's Avatar
    [IMG=1125x2436]https://uploads.tapatalk-cdn.com/20191014/7989c1d4d63b9047b5e577ca92c22315.png[/url]
    Thanks for the suggestion. I'll give that a try.
    10-14-2019 09:54 AM
  4. dsignori's Avatar
    I am also having problems finding alternate Alarm clocks , but ones that pop OVER the lock screen. Many of them I need to unlock the phone first, which is a PITA. I know it's not exactly the same, I can post a separate thread if needed.
    If anyone finds any good ones that open over the lock screen (and can be interacted with over the lock screen - Snooze, etc), that would be great.
    10-14-2019 05:18 PM
  5. TripleOne's Avatar
    I use Sleep Cycle. It’s not the loudest, but it wakes you up at your lightest sleep.
    10-20-2019 04:20 AM
  6. vizagdude's Avatar
    I was havnig the same issue with iOS 13. Then I realized once I disable the Bedtime app and just go with the regular Alarm, with Alarm as sound, it's pretty loud and it's all good now. Hope this helps!
    10-21-2019 06:42 PM
Similar Threads
  1. Replies: 34
    Last Post: 10-27-2019, 07:34 AM
  2. Replies: 12
    Last Post: 10-14-2019, 07:59 PM
  3. Get a better view behind you with 40% off Auto-Vox's Wireless Backup Camera
    Last Post: 10-11-2019, 03:12 PM
  4. Pick up the new app-enabled GeoZilla GPS Tracker at a $5 discount
    Last Post: 10-11-2019, 01:51 PM
  5. Twitter for Mac is now available to download on the Mac App Store
    Last Post: 10-10-2019, 09:51 PM
