1. Nepaiphone's Avatar
    I have a new iPad Pro M1 and am seeing a ton of battery drain just sitting and its all coming from the Findmy App (background activity) web search is showing it may be AirTags, are we saying I cant have any AirTags?
    06-30-2022 03:19 PM
  2. Just_Me_D's Avatar
    Unless you’re actively running the “Find My” app for a significant amount of time, it should not be draining your battery the way you’ve described.
    06-30-2022 08:22 PM
Similar Threads
  1. New M2 13-inch MacBook Pro teardown shows it's just the old one in disguise
    Last Post: 06-30-2022, 12:22 PM
  2. Get the Malzeno Pro Controller for Switch while it's available
    Last Post: 06-30-2022, 12:00 PM
  3. Apple may have multiple 2024 OLED iPad models in the works
    Last Post: 06-30-2022, 05:22 AM
  4. M2 MacBook Pro hits 108 degrees C and exposes 'severe throttling'
    Last Post: 06-30-2022, 04:12 AM
  5. iPad can still be your home hub in iPadOS 16, but there's a huge catch
    Last Post: 06-28-2022, 06:30 PM
