1. Honey Beagle's Avatar
    Hooked this up to my iPad pro. Then the iPad began charging. Then every few seconds the iPad would make a noise like it was connecting to the caarger.
    My iPhone charged perfectly using thus same charger. Any ideas why thus would happen to IPad Pro?
    01-14-2020 04:27 PM
  2. Just_Me_D's Avatar
    The same thing has been happening for quite some time with a 12.9' iPad Pro we use at work when testing certain apps. It would even do it when connected to my work-issued MacBook Air. Since it's not mine, I haven't really taken the time to troubleshoot it. I just read your post and wanted you to know that I have also witnessed that type of behavior with the 12.9" iPad Pro.
    01-14-2020 07:08 PM
  3. Honey Beagle's Avatar
    Appreciate the reply. Should make that noise on all devices.
    01-14-2020 07:11 PM
  4. Wotchered's Avatar
    I have the little Anker Power Port Atom PD1 and when I plug in my 2017 plain vanilla iPad 5 the tone will sound,and repeat a few seconds later, just once.
    I got that bassackwards ! my XS sounds twice !
    01-15-2020 09:37 AM
  5. Honey Beagle's Avatar
    Well I hooked up the same iPad up last night. No repeated noises. Maybe I did not have the charger connected good. Never used this type of charger before.
    01-15-2020 10:32 PM
Similar Threads
  1. Replies: 4
    Last Post: 01-14-2020, 04:42 PM
  2. Score two nylon-braided USB-C fast charging cables for only $7 right now
    By iMore.com in forum iMore.com News Discussion
    Last Post: 01-14-2020, 04:12 PM
  3. Catch the big game on TCL's 55-inch 5 Series 4K Roku TV now down to $280
    Last Post: 01-14-2020, 03:51 PM
  4. Power up at a discount with 50% off Aukey's 40W USB Wall Charger at Amazon
    Last Post: 01-14-2020, 01:22 PM
  5. The Jabra Elite 75t are a worthy alternative to AirPods
    Last Post: 01-14-2020, 12:12 PM
