1. Jamie Wooten's Avatar
    Ok guys I have some issues and I’m wondering if I’m alone. Ever since iOS 11 I keep getting this message that my Smart Keyboard is not supported, I mean really? It’s an Apple product.
    Then last night I left my iPad on my desk and by morning the battery was dead. I know that when I left it, I had about 85% left and I turn off cellular because i don’t have it on a plan. Any advice or thoughts??
    01-10-2018 02:46 PM
  2. TripleOne's Avatar
    It does happen from time to time. Try hard resetting your iPad and see if that solves the problem. If it still doesn’t fix the issue, then I’d recommend paying a visit to the Apple Store to get it checked out.
    Jamie Wooten likes this.
    01-10-2018 07:21 PM
  3. Just_Me_D's Avatar
    Constant attempts to connect to a network with a weak signal is one of the top reasons for quick battery draining. Having said that, are you certain your iPad wasn’t searching for a cellular or Wi-Fi network the entire night?
    01-10-2018 08:45 PM
  4. Ledsteplin's Avatar
    "Not Supported" can mean a bad connection somewhere. I get that message when a charge cable gets a short in it.
    01-10-2018 10:39 PM
  5. Jamie Wooten's Avatar
    I’m 99% certain it wasn’t searching but I’m gonna put it in airplane mode tonight to test it out. Thanks.
    01-10-2018 11:16 PM
  6. Jamie Wooten's Avatar
    Well I just got a new update notification so we’ll see if that helps. Thanks.
    01-10-2018 11:16 PM
Similar Threads
  1. X and 7p mirroring each other.
    By tikchowdhurry in forum iPhone X
    Last Post: 01-10-2018, 02:33 PM
  2. How to hide your ex in the Photos app on iPhone, iPad, and Mac
    By iMore.com in forum iMore.com News Discussion
    Last Post: 01-10-2018, 10:10 AM
  3. Replies: 0
    Last Post: 01-10-2018, 07:10 AM
  4. Zurich Apple Store evacuated after iPhone battery overheats during repairs
    Last Post: 01-09-2018, 04:10 PM
  5. Replies: 0
    Last Post: 01-09-2018, 03:00 PM
