1. playzabass's Avatar
    Hello. I just got my IPad Pro 128 this past Wednesday, and noticed that the system sounds and notification sound a are extremely low. I checked the Apple Forums and I'm not the only one having this issue. Playing music and videos, the sound is amazing.. Anyone else having these issues?
    11-13-2015 02:23 PM
  2. TechnologyTwitt's Avatar
    FYI
    I see the post on the Apple Forum & it's been answered...
    11-13-2015 03:41 PM
  3. TheRadBear's Avatar
    FYI
    Is this the one?
    Beside the OP, is there anyone experiencing it?
    Thanks.
    11-13-2015 04:56 PM
  4. TechnologyTwitt's Avatar
    Yup - that's what I saw.
    11-13-2015 08:03 PM
  5. dvcrob's Avatar
    Did not notice, until I saw this post.
    11-14-2015 03:32 AM
  6. e911emt83's Avatar
    Same here... Its annoying
    11-18-2015 11:08 AM
  7. spain4siempre's Avatar
    I'm having the same issue! Speakers are fine but when I get a text or email or any other notification the sound is soooooo faint I can barely hear it. I called apple support and of course they are clueless..... Hopefully a solution will come soon!
    11-18-2015 04:58 PM
  8. TheRadBear's Avatar
    Hey,
    Just out of curiosity, have you tried adjusting the notification and system alerts volume in the Settings? Sorry if I missed that info.
    Cheers!
    spain4siempre likes this.
    11-19-2015 11:06 AM
  9. spain4siempre's Avatar
    Yes I did. No help...... That's what Apple rep said to do but it is having the same issue. Whether I adjust it in sound settings or the volume control, the system sounds are very faint
    11-19-2015 11:52 AM
  10. TheRadBear's Avatar
    Sorry to hear, mate. Mine does not seem to have the problem. That being said, I have noticed that there is a certain threshold (low level volume) up to which the system sounds are quite faint. I would say, 20% and up they spring to life.
    Cheers.
    TechnologyTwitt likes this.
    11-19-2015 11:17 PM
  11. COMMISSIONERHBK9's Avatar
    it sucks that the systems sounds are so low. any update on when it will get fix.
    11-20-2015 09:19 AM
  12. spain4siempre's Avatar
    I went to apple today and exchanged mine and I'm sorry to say that I'm still having the same volume issues, so at this point I'm sure it is a software issue and will be fixed with an update..... I hope this helps a little!
    11-24-2015 06:44 PM
Similar Threads
  1. Replies: 5
    Last Post: 11-29-2015, 01:21 PM
  2. Replies: 5
    Last Post: 11-14-2015, 11:48 PM
  3. Replies: 1
    Last Post: 11-13-2015, 01:32 PM
  4. iPad Pro supports USB 3.0, but you'll need an adapter
    By iMore.com in forum iMore.com News Discussion
    Last Post: 11-13-2015, 01:22 PM
