You have to buy a separate USB c to lightening cable and use the 29w plug that ships with the MacBook/MacBook Pros and which can also be sold separately. So pretty expensive, all in all. If you already have a 29w plug then it is more worthwhile - the lightening to USB C cable is £35 (I live in the UK so it might be cheaper state side).
