1. wirelessspeakersCA's Avatar
    I also have the same problem can anyone have a good answer been searching for centuries for the right answer.
    07-28-2017 12:28 AM
  2. wirelessspeakersCA's Avatar
    Bone Collection iPad Horn Stand im using it for my iPod
    MasterDarque likes this.
    08-14-2017 01:24 AM
  3. paigem2002's Avatar
    what i did was go onto settings then music then turn OFF volume limit and press it and make sure it’s at the max volume
    10-01-2017 03:54 PM
  4. mogelijk's Avatar
    I'm curious if paigem2002's suggestion has helped you at all? If not, hopefully we can get people in here with other potential fixes. Unfortunately, I never had an issue with my iPad Air and Bluetooth (and no longer have my iPad Air), and can't think of any better suggestions.
    10-02-2017 08:39 PM
29 12
Similar Threads
  1. audio
    Last Post: 10-27-2013, 08:22 PM
  2. How do I adjust ringtone volume?
    Last Post: 10-25-2013, 08:29 PM
  3. Low Light Video Recording
    By JDabney in forum iPhone 5s
    Last Post: 10-25-2013, 01:42 PM
