bluetooth audio volume low
MisterMe11
Oct 2, 2013
17
Connecting to a Logitech Squeezebox boom through a Bluetooth adapter, and the volume is very low even at 100% on the iPad and 100% on the Squeezebox.
Does anyone know a way to boost it? Other phones/tablets have higher volume. Thanks
pkcable
Q&A Team Leader, VR Expert
Jun 16, 2009
5,827
28
Have you tried re pairing? Delete the profile from the ipad and from the device and then start over. :) Worth a shot. :)
nnemeth
Dec 7, 2013
This is not a helpful hint. We all try to re-pair as this is the basic move. It is evident. The volume is still low. I assume the software should be improved that the users cannot help. Any better hint is very welcome as we cannot do anything with the recent software I guess.
medic79
Nov 15, 2013
I've noticed that when I pair my beats wireless headphones that after about 5 min of listening they cut out and I need to delete the pairing and repair them. It's really annoying and only happens on the new ipad air, no issues with iPhone 4S, iPod touch, MacBook Pro. But when it does work the sound is great
Rick Harris1
Dec 23, 2013
I have same/similar problem with iPad 3 and Vizio soundbar. The pairing went perfectly and the audio was great...later when I tried to play music again, the volume was incredibly low. Paired with Android tablet and all is well...it's something to do with the iPad.
anon(52425)
1,508
11
Can't say I have this problem on my JBL Pulse speaker. That's odd.
WarrenLewis_3
Dec 28, 2013
I had the same problem with an aftermarket Bluetooth kit for my car. To get to the Bluetooth volume you have to connect to the Bluetooth device then make or receive a phone call. When you do it pops up a page where one of the options is Audio Source, in my case I had three choices (the Bluetooth car kit, the iphone, and the iphone speaker). I selected Bluetooth car kit and then pressed the '+' volume button on the side of the phone up to the max. It worked. I could never find any other place where you could set the Bluetooth volume.
b3boy
May 10, 2014
Yes, I found the way of using the side buttons to control bluetooth volume when phoning but on the next call it always defaults to the low setting again unlike 'Phone' and 'speaker' options which retain their settings until changed. If anyone knows how to turn this off or make a user default I'd love to here it. Meanwhile I've written a fairly detailed letter to Apple about this. I hope others do the same.
flagalpha
Aug 7, 2014
Thanks pkcable and johnJoseph5 ! :))
This nil volume issue drove me up the wall last night! grrr.
I tried 'reconnecting' several times - that was no help.
The trick is in telling your ipad to forget the device. ... (touch the little blue ringed "I" icon for this option)
Vincent Mohanna
May 6, 2015
I just fixed the same issue I had with my iPhone 4S and an iHome Bluetooth wireless speaker.
I went to settings and used "forget this device" on the iPhone. I then reconnected to the Bluetooth speaker and now the sound level is back to normal.
laoudi
Apr 18, 2016
Hi everyone,
I'm desperate. I tried eeeeeverything I found on several forums, including the advice provided by Apple, turn off Facebook, re-pairing, forget the bluetooth device and connect it again, change the volume via screen and buttons, change the sound settings on the Facebook app, change the audio settings of the iphone, etc. and I'm forgetting some.
Would you have any other advice please ? The volume on my bluetooth speakers used to be way higher, I don't know why it changed. When I try to call someone while I'm connected to Bluetooth, the volume is really high, like it should be, but as soon as I change it back to music ... Low.
I have an IPhone 5C.
Thank you !!
Diana Garcia4
Jun 30, 2016
Were you able to find a solution for this? We have a big blue party bluetooth speaker and anytime we connect via bluetooth the volume is very low.
williams77
