1. iMore Question's Avatar
    I can't pair/connect my Sony headphones with my iPad Air 2 when scanning for Bluetooth devices. The headphones they are not recognised when scanning. The headphones pair and work fine with my iPhone 6. I have not been able to pair anything with the iPad.
    Does anyone have any tips on how to get my iPad's Bluetooth connecting??
    01-10-2016 02:43 PM
  2. Tien HQ's Avatar
    As far as I remember, you need to press one of button on the headphone, press and hold in 10 seconds. Then your iPhone will be able to detect the headphone, after that input the code which were written in users' manual of headphone. Good luck
    01-12-2016 04:29 PM
  3. robertk328's Avatar
    Have you enabled Bluetooth on hour iPad? You can do it from control center by swiping up from the bottom of the screen. Otherwise go to Settings -> Bluetooth
    It might help to have that Bluetooth settings screen up when trying to pair to see if it registers any devices.
    01-12-2016 04:49 PM
Similar Threads
  1. For those who have used it, how is the Pencil on the iPad Pro?
    By iMore Question in forum iPad Pro (12.9-inch)
    Last Post: 02-27-2016, 08:36 PM
  2. Will my current iPad apps work on the iPad Pro?
    Last Post: 01-23-2016, 10:53 AM
  3. Are there any apps that are made just for the iPad Pro?
    Last Post: 01-14-2016, 08:37 AM
  4. How can I tint my iPad Pro so I can read it in bed?
    Last Post: 01-12-2016, 12:23 AM
  5. Is there GPS on the iPad Pro?
    Last Post: 01-10-2016, 01:51 PM
