1. bunjy's Avatar
    My iPad Pro 9.7 has been rapidly draining battery power ever since I updated to iOS 11.4.1. I took it to the Genius Bar and their diagnostics said that the battery was good. They put the iPad into DFU mode and reloaded the OS. We set the iPad up as new rather than restore. And still the battery is rapidly draining. I’ve turned off location services, background refresh and email push. Is there anything else that I can do?
    07-29-2018 05:15 PM
  2. Just_Me_D's Avatar
    Let the device settle for a day or two with the new iOS installation. In addition, go through each setting (device and app) to make sure things are as you like them. I also recommend paying attention to the battery settings to see what is utilizing the most battery consumption.
    07-29-2018 05:23 PM
  3. aniss.kais's Avatar
    Mine had also crapy battery drain, then I updated to iOS 12 bêta and now everything is running just fine
    07-29-2018 11:44 PM
  4. bunjy's Avatar
    I’m considering this. Can’t wait to put iOS 11 in the rear view mirror.
    aniss.kais likes this.
    07-30-2018 11:02 AM
  5. aniss.kais's Avatar
    iOS 11 has just ruined my iPad Pro 9,7. The animations were very laggy, the battery was draining crazy fast, especially when using YouTube. Since I updated to iOS 12 beta 3, I found all the power I lost. I’m discovering again my device. Suggest you to update to the latest beta. Runs really like a final release, and infinitely better than all iOS 11 versions
    bunjy likes this.
    07-30-2018 11:09 AM
  6. bunjy's Avatar
    Thanks for the feedback. I may give this a try.
    07-30-2018 06:43 PM
  7. Evilguppy's Avatar
    My iPad Pro 9.7 has been steadily “drying up” for a while now. I have no idea if this is due to iOS 11 or if it’s just getting long in the tooth (it’s my main device, I don’t use a laptop anymore) but it hiccups like a drunken old sailor after a greasy meal and I want a new one.
    09-11-2018 11:13 AM
  8. Lee_Bo's Avatar
    11.4 was just fine on mine and 12 runs great also. And I use mine daily with several apps like what you see on HGTV except for pro a/v installs.
    09-11-2018 12:44 PM
Similar Threads
  1. Should I get the current 12.9" iPad Pro now or wait for the next one?
    By Marcin Dabrowsky in forum iPad Pro Series
    Last Post: 09-10-2018, 08:28 AM
  2. Screen phantom touch issue?
    By jgraves1107 in forum iPhone X
    Last Post: 08-03-2018, 03:30 PM
  3. Pumatrack issues
    By lolmit in forum iPhone Apps & Games
    Last Post: 07-28-2018, 03:29 PM
  4. How to delete iMessages on iPhone and iPad
    Last Post: 07-28-2018, 02:10 PM
  5. How to print and share from Photos for iPhone and iPad
    Last Post: 07-27-2018, 03:10 PM
