1. princessiphone's Avatar
    I don't mind iOS 11 beta and wanted to try it. I thought I had an icloud backup on ios 10 but i dont think i do...
    Does anyone know if I back it up with iOS 11 then downgrade will I still have everything saved?
    Please someone help! If not, I can always stick with it, but the battery drain is bad!
    06-30-2017 11:16 PM
  2. Tartarus's Avatar
    Backups on higher versions can’t be restored to lower versions.
    In other words, what you want is not possible.
    07-01-2017 12:31 AM
  3. blueeyes2die4's Avatar
    You can’t restore a iOS 11 backup to iOS 10. If you don’t have a backup from iOS 10 unfortunately you will lose all data if you downgrade.
    princessiphone likes this.
    07-01-2017 12:31 AM
  4. princessiphone's Avatar
    Is there a way I can check if I have an ios 10 backup? I don't know if I do.
    07-01-2017 01:04 AM
  5. blueeyes2die4's Avatar
    Hope this helps.
    07-01-2017 01:13 AM
  6. TwitchyPuppy's Avatar
    You can see your backups, if any, but not if they’re on iOS 10.
    Not until an attempt to restore from an iCloud backup.
    07-02-2017 06:47 AM
Similar Threads
  1. Instagram insights are only available for new posts.. help!!
    By TallShadow in forum Ask a Question
    Last Post: 06-30-2017, 06:06 PM
  2. Uber - Everything you need to know!
    Last Post: 06-30-2017, 08:10 AM
  3. How to downgrade from macOS High Sierra back to macOS Sierra
    Last Post: 06-29-2017, 05:40 PM
  4. Replies: 0
    Last Post: 06-29-2017, 04:10 PM
  5. Apple Trade-Up program: Everything you need to know!
    Last Post: 06-29-2017, 01:50 PM
