Amanda Drake
Sep 12, 2016
19
I think the rest to finger option is switched on. Please turn it off and then try. The option is in settings under General > accessibility > Home Button.
If this does not work then remove your previous fingerprint and add new.
It only happens when phone is on charge
Prakhar Mohan1
259
ok got it. It happens to mine also when my phone is on charge. There is a problem with your electrical point. Just ask the electrician to check for the earthing in the power socket. Mine was solved.
anon(9776449)
228
I have no problems now. It's simple amazing. But I had trouble downloading. Almost 1 hour to download and then it ask me to connect to iTunes. Then it took almost 7 hours to install iOS 10 on my iPhone. At the end I had to erase my phone and set up like a brand new.
But now it's fine. Really enjoying.
Prakhar Mohan1
259
That depends upon the wifi connectivity and the phone storage. The more the storage , the more time it takes to update.
Rob Phillips
Champion
May 1, 2012
13,759
Just to clarify for everyone else, that was an issue that occurred during the first hour or so that iOS 10 was available for download. It was patched by Apple and shouldn't be occurring with any new downloads.
Prakhar Mohan1
259
People who all are facing the same sound issue for whatsapp and imessage after ios 10 update. Please just restart your device and problem will be solved.
anon(9776449)
228
Yeah! I've heard that too. But thank god. I was about to die when it happened.
mhansen6969
Sep 15, 2016
you have to download the language pack in language under settings for that to work
Thank you. Unfortunately, the New Oxford American Dictionary is stuck trying to downloading (circle with a stop sign), and won't do anything. I've run into far too many issues with iOS 10, I'm reverting back iOS 9.3.5. I appreciate the help though!
Prakhar Mohan1
259
i would suggest you not to. As there are just initial hick ups and within a week or to they would disappear. ios 10 is by far better than ios 9. Rest depends upon you and your usage.
Ledsteplin
Oct 2, 2013
50,237
706
108
I've had no issues like that. Did you try a hard reset? I like iOS 10 a lot. Give it time.
Prakhar Mohan1
259
Sir the best thing is to do a hard reset after a huge update that solves all the issues arising for few people...iOS 10 is by far the best os version
dsmccormick
Dec 23, 2014
I have 10.0.1 installed on an iPhone 6s and the battery widget doesn't show any batteries. This was reported in the developer betas from what I saw in Google, but the iMore iOS 10 guide shows a working battery widget. Did this happen to anyone else?
Prakhar Mohan1
259
True... i've reset it and everything just fine.
I know. As we know, when we update the OS then new settings get modified and in this process some features tend to do not work. The best way is to do a hard reset after a major update and then restore via backup.
Most of the problems would be solved by this process.
truenorthstrong
286
How come I can't find the Mac, hearts stickers for iMessage that were there on the beta. Also SwiftKey has been highlighting words when I type in other languages.
FrankRow
81
I've noticed these two issues/glitches as well. I'm running it on iPhone 6plus. Maybe it's the lack of processor power compared to the 7. But I hope they fix it as well on the coming updates.
Gokox
