iOS 9.3 and battery indicator issue
Sherry_B
2,687
Seems I remember someone somewhere here on the forums mentioning that the issue went away for them after they updated. I wish I could recall where I saw it. I only saw it from one person though.
billyboydoy
281
i have the same problem just started after update to 9.3 and now when i charge the phone the indicator stops on 86% or sometines on 96%
Ledsteplin
Oct 2, 2013
50,267
707
108
Try a hard reset:
Hold the top or side power/sleep button and the home button at the same time until the Apple logo appears, then release.
You might also calibrate it by running the battery down to 1%, then charge it all the way up to 100%+.
MooMooPrincess
1,741
I think it was in the beta thread. I do know a few youtubers said 9.3 fixed that battery issue.
Tomwex73
