1. Pandurr's Avatar
    I see and experience myself bad Wifi connection on the newest available update (IOS 8.3). I keep getting disconnected from the wifi. Will there be a fix for this on the IOS 8.4? (My older iphone is still on the 8.2 and the wifi works great on that one).
    06-09-2015 08:51 AM
  2. Bigeric23's Avatar
    I'm not seeing any issues with Wi-Fi on iOS 8.3. So, I don't notice any difference with WI-Fi on iOS 8.4. Are you having issues everywhere, or just at home?
    06-09-2015 08:55 AM
  3. kch50428's Avatar
    I've not had the wifi issue... one of the things 8.4 is supposed to deal with is wifi - and those here running the beta haven't complained about wifi that I've noticed.
    06-09-2015 08:57 AM
  4. Ledsteplin's Avatar
    Reboot your WiFi modem/router, then reset network settings.
    Reset Network Settings
    Settings>General>Reset>Tap Reset Network Settings. You may need to enter your wifi passcode back in afterwards.
    If that doesn't work, check with your WiFi provider.
    06-09-2015 09:03 AM
  5. Pandurr's Avatar
    I have tried everything..
    06-09-2015 09:10 AM
  6. Pandurr's Avatar
    well many people have complained about the wifi when they updated from 8.2 to 8.3
    06-09-2015 09:10 AM
  7. HankAZ's Avatar
    I have no issues with wifi. But it's always a point of focus on the new versions.
    06-09-2015 11:31 AM
  8. Pandurr's Avatar
    looking forward to it!
    06-09-2015 12:09 PM
  9. Just_Me_D's Avatar
    For those of you who experienced Wi-Fi related issues, hopefully it'll fix it for you.
    06-09-2015 12:10 PM
  10. katesbb's Avatar
    I keep getting disconnected from the wifi. Will there be a fix for this on the IOS 8.4?.
    I had the same problem with my iPhone 6, iPad Mini 2 and MacBook. I'd rarely stay connected for more than a day or two.
    After trying everything I could think of, I ended up going back to using an older Router I had in my junk drawer. I haven't lost a connection since then (months now).
    Curiously, the other iPhone 6 in the house never had a problem, nor did the PCs, androids or BlackBerry.
    06-09-2015 01:38 PM
  11. Ledsteplin's Avatar
    There's always a chance the wifi hardware in the phone could be bad. I would have it checked out at an Apple Store or the carrier store.
    06-10-2015 10:13 AM
  12. katesbb's Avatar
    I wondered about that too. I can't swear it isn't the WiFi in the devices being bad, but all three gadgets wouldn't stay connected with the old router/modem/WiFi, while all three have worked perfectly with the new router/modem/WiFi for months.
    And curiously, when I'd lose my connection, I actually COULD still see the local network - I just couldn't get past the router to the internet. I could use AirPrint, for example, so I'm guessing there's something my original router didn't like about whatever communications was going on between them (all three gadgets use the same Apple ID, while the lone iPhone that did work doesn't share it's AppleID with any other devices).
    So I'd suggest that people seemingly having WiFi problems might consider trying a different router. It might not be a WiFi problem after all.
    06-10-2015 11:05 AM
  13. HankAZ's Avatar
    I just saw an article this morning on 9to5Mac that said iOS 9 will follow OS X in dropping discoveryd for mDNSResponder to improve network stability.
    06-10-2015 11:09 AM
  14. Pandurr's Avatar
    Bought a new router today and I have not disconnected from the internet yet. Works very great now.
    06-10-2015 05:27 PM
Similar Threads
  1. Replies: 2
    Last Post: 06-29-2015, 12:40 PM
  2. Bose releases two new colored variants of the QuietComfort 20 noise cancelling headphones
    Last Post: 06-09-2015, 08:12 AM
  3. Why can I not get back to the main menu once I get into an app?
    Last Post: 06-09-2015, 06:02 AM
  4. Why is my ipad not charging and what should I do to fix it?
    Last Post: 06-09-2015, 02:37 AM
  5. Hi I work a shift work days and nights and the schedule goes 554
    Last Post: 06-09-2015, 02:09 AM
