Will they fix the 8.2 problem with bad elf or will 8.4 be out soon?
I
iMore Question
Will 8.2 fix the problem with bad elf or will 8.4 be out sooni
I had no problems with my bad elf before ISO 8 came out now I can not use it at al
kch50428
21,025
305
Re: Will 8.2 fix the problem with bad elf or will 8.4 be out sooni
It broke with the public 8.3 release... It's fixed in the 8.4 betas I'm running... My BadElf device works normally on 8.4 - which may go public with the WWDC coming soon.
smitty22d2
