Save on M1 iPad Pro: $100 off at Amazon
  1. AB Lambert's Avatar
    All,
    I figured out that Four Square was draining my battery on my iPhone 6. I started to notice my battery was draining faster than expected.
    I went to look at the battery utilization feature and was only seeing the apps I was using at the top of the list.
    I also was looking at the privacy feature and noticed that Four Square was always using the location feature (or just used it) when I looked. I decided to delete Four Square and noticed for 3 days after that my batteries performance improved significantly.
    Has anyone had the issues?
    Thanks,
    A.B.
    fabio984 likes this.
    10-15-2014 08:12 AM
  2. bamf-hacker's Avatar
    I am not sure if the FourSquare app has the option yet, but one of the new location features is to set an app to only use location services when the app is in use.
    If you reinstall it you might want to check that.
    AB Lambert likes this.
    10-15-2014 08:28 AM
  3. AB Lambert's Avatar
    I did and the option was not available. I also try to see if I could do something within the App.
    Thanks,
    A.B.
    10-15-2014 08:33 AM
  4. bamf-hacker's Avatar
    The app developers need to update their apps to make it available. I am guessing FourSquare is focusing on their Swarm app
    EmceeGeek likes this.
    10-15-2014 08:39 AM
  5. AB Lambert's Avatar
    Battery is still performing much better since I uninstalled Foursquare.
    10-16-2014 07:58 AM
  6. fabio984's Avatar
    EDIT: I don't want uninstall foursquare without be sure it drains my battery :|
    Do you use swarm? I have it installed too.
    Are you sure it was Foursquare? Can be coincidence...
    You received less emails, or used the phone more with foursquare...
    10-20-2014 05:05 PM
  7. fabio984's Avatar
    Four Square was draining iPhone 6 battery but saw nothing in battery utilization-imageuploadedbytapatalk1413893527.881895.jpgFour Square was draining iPhone 6 battery but saw nothing in battery utilization-imageuploadedbytapatalk1413893542.513948.jpg
    Changed my settings .
    10-21-2014 07:12 AM
  8. fayeav's Avatar
    I deleted four square because it keeps gps open! :-) That was before ios8!
    10-21-2014 08:19 AM
  9. CrzyP's Avatar
    Make sure you also have the background location turned off in the app too.
    10-21-2014 08:24 AM
  10. anon(52425)'s Avatar
    I thought Foursquare shut their doors a while ago.
    10-21-2014 09:23 PM
  11. fabio984's Avatar
    Make sure you also have the background location turned off in the app too. http://tapatalk.imageshack.com/v2/14...e04a862d63.jpg
    I think I've done?
    Ios8.1 settings locationservices:
    Four Square was draining iPhone 6 battery but saw nothing in battery utilization-imageuploadedbytapatalk1414134466.878062.jpg
    10-24-2014 02:07 AM
  12. AB Lambert's Avatar
    I am going to try FourSquare again and we will see what happens!
    A.B.
    01-08-2015 06:17 AM
Similar Threads
  1. Replies: 8
    Last Post: 10-20-2014, 07:35 AM
  2. Angry Birds Transformers rolls out worldwide for the iPhone and iPad
    Last Post: 10-15-2014, 07:00 AM
  3. Samsung achieves download speeds of 7.5 Gbps in super-fast 5G test
    Last Post: 10-15-2014, 05:51 AM
