1. jaleelhamid's Avatar
    I have always been in the understanding that auto brightness drains the battery but after ios 8 when you go under battery usage it recommends that auto brightness be turned on? Any thoughts
    09-22-2014 11:35 PM
  2. Ledsteplin's Avatar
    Depends on how you use it. The idea is to keep the brightness down as much as possible. If auto brightness helps you achieve that, then yes it does. A bright screen will eat battery worse than anything else.
    Sent from my ancient but trustworthy iPhone 5
    09-22-2014 11:45 PM
  3. Reparkable's Avatar
    Huh. It's always been my understanding the auto brightness would save battery life. In theory it adjusts itself to the environment your in hence saving power.
    I permanently have it always on and never concerned with battery power.
    jaleelhamid likes this.
    09-22-2014 11:51 PM
  4. EmceeGeek's Avatar
    For years I've heard to turn auto brightness off to save battery. The lower the screen brightness the better.
    09-23-2014 08:56 AM
  5. usedberry's Avatar
    Does Auto brightness help save battery?-imageuploadedbyimore-forums1411477723.517695.jpg
    If you like the screenshot. I always have it enabled and enjoy great battery life.
    Sent from my iPhone 5c or iPod touch 5th Gen using iMore Forums
    09-23-2014 09:10 AM
Similar Threads
  1. Replies: 2
    Last Post: 09-22-2014, 08:57 PM
  2. Urgent Help Needed:Privacy Family Sharing
    By usedberry in forum iOS
    Last Post: 09-22-2014, 10:37 AM
  3. WiFi issues - Help me keep connected
    By Gooner26 in forum Ask a Question
    Last Post: 09-22-2014, 09:53 AM
  4. How long does it typically take to upgrade to iOS 8?
    Last Post: 09-22-2014, 09:44 AM
  5. Does the iPhone 6 camera stick out further?
    By bigdad84 in forum iPhone 6
    Last Post: 09-21-2014, 08:20 PM
