Originally Posted by
Nexevious Hey,
So I'm trying to jailbreak this thing so that I could unlock it afterwards. Although, the power button is broken. I've been trying for hours and I have no luck. I can put it in DFU mode with redsn0w, but it just got stuck on the 'Downloading jailbreak essentials' (or something like that). I clicked to install iPad baseband (with a YouTube video) and it seemed to have worked. It is currently on DFU mode, but something happened, it was on the New Bootrom before the jailbreak attempt, but when its connected, under redsn0w it says 'iPhone 3GS (DFU mode, Old BR)' did it work?
I am usually good at these things, but the lack of the power button and the fact that it is on 6.1.6 angers me. Any help is appreciated, thanks!
I have a 3GS with a bad lock/sleep button. I connected it to iTunes and hit the restore button. It installed 6.1.6. Then I used posixnw I think that's how you spell it, jail break took fine. I had no need to use the lock/sleep button though the entire process.
Then I installed activator to simulate the lock button with a gesture. Install ncsettings too so you can power down and reboot from the notification center.
